bosch pump
Deadsfo
bosch pump
I will soon be changing the fuel filter on my Mercedes 508 om314 engine ,is there a hand operated air bleed pump somewhere in the fuel system
- Arno Z
Re: bosch pump
The red knob on top of the fuel pump is a bleeding pump. Turn it counter clockwise a few revolutions then pull it out. Open the bleeding screw (next to the pump) and start pumping until fuel drops from the blessing screw.
Close everything up and try and start the engine.
Deadsfo
Re: bosch pump
Thank you will have a look tommorow
