Wheel bearing socket 508d
Wolvesamongus
Does anyone know the socket size or can give a link for purchase of the socket for The wheel bearing locking nut for my 508d, I know it can be done with a hammer and screwdriver but I would prefer the correct tool.
Regards-------kim
Regards-------kim
Re: Wheel bearing socket 508d
I no longer have a "Düsseldorfer" (generic name for the range 406 - 613), so I cannot measure the right size for you. But I remember very well that even a small hammer and a narrow chisel easily do the job. That is: once you have flattened the locking plate. If you forget to flatten the plate first, you'll ruin the nut, but after you have flattened it, the nut comes off almost without any force.
The nut is so shallow it is hard to put a socket on it.
Wolvesamongus
Thanks for the reply Ernst, I guess I'm to much old school I was always taught use the right tool for the job but if I can't locate it I'll do the hammer and chisel thing.
Regards-----kim
Regards-----kim
So am I..... but sometimes hammer and chisel ARE the right tools
I thought it's a 64mm.
Wolvesamongus
Thanks for the reply Yoni, 64mm castle socket yes? I have not taken the wheel of yet I think the nut has six points of insert for the socket.Yoni schreef:I thought it's a 64mm.
Regards-----kim
- GerardM
Good that you guys have an answer, I am still trying to understand which part Kim actually means...
Wolvesamongus
Lol Gerard, many words I write get lost in translation sometimes I read back that what I have written and think WTF like insert which appeared as utility, a picture would make it easier I think, I want one of these for a 508d bearing lock nut in the right size.
- GerardM
Ah, this one :-).
Indeed screw driver and hammer in delicate hands will do the job.
Good luck,
Good luck,
I'm sorry the bearing cap is 64, the locking nut i don't know, never used a other tool than chissel and hammer
Wolvesamongus
Thanks Yoni, well I guess I'm a member of the hammer and chisel club now, needs be needs must.Yoni schreef:I'm sorry the bearing cap is 64, the locking nut i don't know, never used a other tool than chissel and hammer
Regards-----kim
