Mysterie-prijsvraag
joy
Re: Mysterie-prijsvraag
Wat is er aan de hand op dit plaatje
-weinig
Wat zit er in de vrachtwagen?
-weggelopen tandartsboor
De schunnige versie durf ik niet te posten, laat niets aan verbeelding over vrees ik)
Waar is de chauffeur?
-bij de dokter
Wat gaat er gebeuren
-de tandartsboor trilt tegen de handrem die losschiet, de wagen begint te rollen en werd vervolgens nooit meer teruggevonden
-weinig
-bij de dokter
Hold-up en hi-fi (Hold-up in Hi-fi)
One morning Yoko enters a bank to make a money transfer to Japan. Suddenly a loud rumbling sound shakes the block, and the police station next door receive a call that a department store in the city center has collapsed. The police under the leadership of Commissioner Lebrun scramble, leaving only one man to monitor the bank. Just then, a team of bank robbers enter the bank while an accomplice knocks out the remaining officer. Yoko fights - and defeats - two of the robbers, but a submachine gun pressed into her back forces her to relent. In the meantime, the police arrives at the store - only to see it standing intact, as it should.
When Lebrun is wondering about the rumbling sound, Yoko provides a hint about a truck which had been parked before the bank. Indeed, it contains stereo equipment and speakers, and a tape with the rumbling on it, but the speakers are too weak. But the same evening, as Yoko takes a stroll in the city, she comes upon two movie spectators discussing the effect of the stereo sound system in the theater.
This comment sparks a suspicion, and above the bank building Yoko indeed discovers the gang as they dismantle two giant speakers and stereo equipment hidden atop the roof. Although she is discovered and locked in, she manages to activate the equipment (which is still hooked up), alerting the police, and then throws a polyester audio tape off the roof, leading the police to the culprits.
Groeten
Paul
Groeten
Paul
- Janneman
- evelyn25
dit is uhm
de agent gaat eens poolshoogte nemen bij de vrachtwagen.
hij is pas begonnen en doodzenuwachtig. hij vermoed een drama of een val.
Hij besluit het slim aan te pakken, maar hij is tevens hardhorend..
hij heeft net voor de derde keer gevraagd wat voor stof zich bevindt tussen selenium en krypton in het periodiek systeem der elementen.
Degene die zich in de laadbak bevindt heeft al twee keer het juiste antwoord gegeven en is het nu zat! met een ietwat geirriteerde toon roept hij nu iets harder en spint de letters nu ook wat langer uit.
De chauffeur past zijn carnavalskostuum, we zien hem nog net linksboven. hij gaat dit jaar verkleed als gemetseld paaltje, wat er gaat gebeuren?
Nu de ingeslotene het antwoord zo luid heeft gegeven is de agent overtuigd van de onschuld en met zijn drieen besluiten ze een broodje te gaan eten en dit weg te spoelen met een glaasje jupiler, uiteindelijk werdt het toch nog gezellig!
508 lang hoog, OM314 uit 1977
Wij willen een truck,... !
het is toch duidelijk of niet dan,...... Het is een mobiele wiet plantage waarbij de groeilampen van stroom worden voorzien door een aggegraat.
De agent ruikt de toppen die onlangs geknipt zijn en die in de vrachtwagen hangen om ze te laten drogen.
De louche chauffeur is hem gesmeerd toen hij de pliesie zag!
Op het moment van het plaatje is de agent net begonnen aan de inval.
- verboon
prijsvraag
Volgens mij is het een illegale camper!
De camper behoort toe aan Rik&Carla, de R en C op het zeil.
Dit echtpaar is hardhorend(zie de luidspreker op het zeil),en hebben geen last van het geluid wat uit de camper komt.
Het geluid komt van een stroom-aggregaat die de stroom opwekt voor de verlichting binnen, er zijn geen ramen in de camper.
Ook dit zie je als symbool op het zeil.
Door deze gegevens op het zeil lijkt het een reclame maar andere illegale campersfreeks weten precies wie het zijn.
De chauffeur zit lekker in zijn camper met de vrouw.
Omdat de agent het een verdachte situatie vind en het achterzeil open staat kijkt hij toch wel heel erg vreemd als hij die twee daar ziet zitten aan de koffie. :D
Mannen blijven kinderen, alleen het speelgoed wordt steeds duurder.
gr Sjaak en Bep
HH F40 KA 1974 motor OM 601.911
gr Sjaak en Bep
lemmy
een antwoord
de vrachtwagen staat te draaien in afwachting van de overvallers die de bank aan het beroven zijn dacht ik.
- patrickjanssen
nou het is geen geheim meer !Saskia en Herman schreef:8) 8) 8) 8) 8) 8) 8) 8) 8) 8) 8) 8) 8) 8) 8) 8) 8) 8) 8) 8) 8) 8)
Prijsvraag voor jong en oud!!!!!!!!
Wat is er aan de hand op dit plaatje?
Wat zit er in de vrachtwagen? Waar is de chauffeur? Wat gaat er gebeuren?
Vragen, vragen, vragen. Wie lost het mysterie op![]()
roger leloup
http://www.dumpert.nl/mediabase/31584/9 ... rror).html
