Voor iedereen die in een donker vooronder de draad kwijt is.... de klemaanduidingen volgens DIN 72552. Sommige aansluitingen zul je niet aantreffen (verouderd), maar omdat Mercedes en Hanomag Duitse merken zijn, wordt de DIN strak gevolgd!
Wie moeite heeft met het Engels, moet zich maar melden.
ONTSTEKING EN STROOMVOORZIENING
1: Coil, distributor - low voltage
1a: To contact breaker I (distributor with 2 separate circuits)
1b: To contact breaker II (distributor with 2 separate circuits)
2: Shorting circuit - magneto ignition
4: Coil, distributor - high voltage
4a: From coil I (distributor with 2 separate circuits)
4b: From coil II (distributor with 2 separate circuits)
7: Ballast resistor terminal to/from distributor
15: Switched + downstream of battery (output of ignition/driving switch)
15a: Output at ballast resistor to coil and starter
17: Glow plug and starter switch - Start
19: Glow plug and starter switch - Preheat
30: Input from battery +, direct 12/24 V series-parallel battery switch
30a: Input from + terminal of battery II
31: Battery negative terminal, or ground, direct
31a: Return line to battery II, negative (12/24 V series-parallel battery switch)
31b: Return line to battery negative terminal, or ground via switch or relay (switched negative)
31c: Return line to battery I, negative (12/24 V series-parallel battery switch)
X: Battery power switched through the load reduction relay
MOTOR
32: Return
33: Main terminal connection
33a: Self-parking switch-off
33b: Shunt field
33f: For 2nd low-speed range
33g: For 3rd low-speed range
33h: For 4th low-speed range
33L: Anticlockwise
33R : Clockwise
STARTER
45: Separate starter relay, output; starter, input (main current)
Two-starter parallel operation - Starting relay for engagement current
45a: Output, starter I, Input, starters I and II
45b: Output, starter II
48: Terminal on starter & on repeating relay for monitoring starting procedure
RICHTINGAANWIJZERS
49: Input
49a: Output
49b: Output, 2nd circuit
49c: Output, 3rd circuit
BESTURING STARTMOTOR
50: Starter control (direct)
50a: Series-parallel battery switch - Output for starter control with parallel operation of two starters with sequential control
50b: Starting relay for sequential control of the engagement current during parallel operation of two starters
50c: Input at starting relay for starter I
50d: Input at starting relay for starter II
50e: Start-locking relay Input
50f: Start-locking relay Output
50g: Start-repeating relay Input
50h: Start-repeating relay Output
ALTERNATOR
51: DC voltage at rectifier
51e: DC voltage at rectifier with choke coil for daytime driving
RUITENWISSER
53: Wiper motor, input (+)
53a: Wiper (+), self-parking switch-off
53b: Wiper (shunt winding)
53c: Electric windshield-washer pump
53e: Wiper (brake winding)
53I: Wiper motor with permanent magnet and 3rd brush (for higher speed)
AANHANGERSIGNALEN
52: Additional signals from trailer to vehicle
54: Trailer plug connections and lighting combinations, brake light
54g: Pneumatic valve for continuous brake in trailer, solenoid-operated
LICHT
55: Fog lamp
56: Headlamp
56a: High beam, high-beam indicator lamp
56b: Low beam
56d: Headlamp-flasher
57a: Parking lamp
57L: Parking lamp, left
57R: Parking lamp, right
58: Side-marker, tail, numberplate and instrument panel lamps
58b: Taillight changeover for two-wheeled tractors
58c: Trailer plug and receptacle assembly for single-conductor tailight with fuse in trailer
58d: Variable intensity instrument panel light, tail light and side marker.
58L: Numberplate lamp, left
58R: Numberplate lamp, right
ALTERNATORS EN SPANNINGSREGELAARS
59: A/C voltage output, rectifier input
59a: Charging armature, output
59b: Tail light armature, output
59c: Brake light armature, output
61: Alternator charge-indicator lamp
B+: Battery +
B-: Battery -
D+: Dynamo +
D-: Dynamo -
DF: Dynamo field
DF1: Dynamo field 1
DF2: Dynamo field 2
U,V,W: Three-phase alternator terminals
MEERTONIGE CLAXONS EN ZWAAILICHTEN
71: Input
71a: Output to horns 1 & 2 low
71b: Output to horns 1 & 2 high
72: Alarm switch - revolving emergency light
RADIO EN SIGARETTENAANSTEKER
75: Radio, cigar lighter
76: Speakers
77: Door valve control
NC SCHAKELAARS
81: Input
81a: Output 1, NC side
81b: Output 2, NC side
NO SCHAKELAARS
82: Input
82a: Output 1
82b: Output 2
82z: Input 1
82y: Input 2
MULTI-PURPOSE SCHAKELAARS
83: Input
83a: Output, position 1
83b: Output, position 2
83L: Output, left-hand position
83R: Output, right-hand position
STROOMRELAIS
84: Input, actuator and relay contact
84a: Output, actuator
84a: Output, relay contact
SCHAKELRELAIS
85: Output, actuator (end of winding to ground or negative)
86: Input, actuator (start of winding)
86a: Start of winding or 1st winding
86b: Winding tap or 2nd winding
N/C EN WISSEL
87: Input
87a: Output 1(NC side)
87b: Output 2
87c: Output 3
87z: Input 1
87y: Input 2
87x: Input 3
N/O EN WISSEL
88: Input
88a: Output 1
88b: Output 2
88c: Output 3
88z: Input 1
88y: Input 2
88x: Input 3
RICHTINGAANWIJZERS
C: Indicator lamp 1
C2: Indicator lamp 2
C0: Main connection for separate indicator circuits worked by turn signal switch
C3: Indicator lamp 3 (e.g., when towing two trailers)
L: Turn-signal lamps, left
R: Turn-signal lamps, right
Nummers aansluitklemmen
